Headphone volume
(Topic created on: 10-13-2022 08:35 PM)
Fredglonn51
TV & Audio
Hello, new to this forum. I have a Samsung TV with Bluetooth. I have hooked up my Bose Quiet Comfort headphones successfully but the volume when the volume on the TV is increased is very low. It will do down, but not up to a higher level than just audible. Any thoughts?
2 Comments
TV & Audio
If you are using the volume control in you headphones, it will not go as high as much as you want too. You need to use your TV's remote for volume to go higher than your headphones.
SamsungLaura
TV & Audio
Hi @Fredglonn51, could you confirm which TV you are using?
