QA65QN85B Samsung Neo QLED 65" Audio Clipping / Dropping over HDMI ARC
(Topic created on: 02-21-2023 08:16 AM)
Adrian_R
TV & Audio
I have a Samsung 65" Neo QLED QA65QN85BAWXXY that is only one month old.
I have audio running to Samsung soundbar via HDMI ARC on HDMI3. The other HDMI inputs have devices connected eg. Cable TV box, Android TV Box and PC.
After 1 month of perfect operation suddenly the audio started to have regular momentary dropouts and subsequenct audio sync problems no matter which input I use, and even using the native Samsung TV apps eg. Media player playing movie off USB on side of the TV.
Doing a full reset of the TV via the menu seems to have solved the problem - but nothing else prior to that would work.
I am thinking this is some sort of bug in the firmware of the unit given that a full reset solved the problem.
Anyone exxperienced this issue ? Or what is the best way to report this bug to Samsung to look into for future firware update ?
4 Comments
SamsungClaudette
TV & Audio
Hello @Adrian_R
I am sorry that you are having this issue.
I would really like to look into this for you.
If you could send an email through to members.au@samsung.com I will have this issue escalated for you.
Subject Title: SamsungClaudette - TV Audio clipping<----Please post this in the Email Subject as well as your community handle.
Name:
Email:
Contact Number:
Proffered call back time: 8am-5pm
State of residence
Model
Serial Number:
Product Issue:
Trouble Shooting Provided:  Cold reboot
                                                          Restart
                                                    Factory Reset
Kind Regards,
SamsungClaudette
HappyCustomerNot
Beginner Level 4
TV & Audio
Hi, I'm having a similar problem with my 65" QN800B Neo QLED 8K Smart TV & HW-Q800B Q-Series Soundbar, right from instillation the HDMI ARC Q connect hasn't worked, I tried it with the HDMI cable it came with and a super expensive 8k cable as well, I did manage after many attempts and robots to get it to work but only until the next time I turned it on then wouldn't turn on again, I can only get it to work with Bluetooth, seems to be a definite issue with either the TV or the sound bar
korayesque
TV & Audio
I have recently bought a Samsung M7 monitor (LS43BM700UPXUF) and I have the same problem with it. I used two different Bluetooth speakers (Logitect & I-WAVE and both of them randomly and momentarily cut out during play. This happens only on apps (i.e., Disney+ or MUBI), but not on HDMI. Using Bluetooth speakers for HDMI sources works perfectly with no problem. It looks like a software/processor issue. I am using the latest firmware.
Can you escalate this to technical team?
Thanks!
K.
Jhaydu
TV & Audio
I have been experiencing a loss of signal as well with my Qn65qn850bf. Had it for a year and had one repair completed already. Now the tv losses signal from cable box and goes blank. There is a clicking sound coming from the back of tv. After a few minutes it comes back on. Hooked another tv  up to cable box and no problem. When i try to stream by wifi, tv still losses signal periodically.  Had cable company look at there equipment and no issues. This occurred after factory warranty expired. Good thing i bought extended warranty. Never had issues with samsung tv's till now.
