Activate Water Lock mode on Samsung Galaxy Watch
(Topic created on: 07-24-2023 09:53 AM)
Samsung_Ryan
Wearables
The Galaxy Watch is rated 5ATM water and dust resistant, which means it can withstand the pool, the rain, or a post-workout shower. Be sure to turn on Water lock mode before swimming or exercising in water. When Water Lock mode is enabled, the touchscreen, the wake-up gesture feature, and watch always on feature will be deactivated.
When you select Exercise > Swimming menu, the Water Lock mode will be activated automatically. To turn off Water lock mode and eject water, press and hold the Home.
How to activate Water Lock
When using your Galaxy watch in or around water turn on Water lock mode to prevent accidental touches on your screen. It will also prevent you from accidentally activating your watch with a wake-up gesture while you're swimming.
Step 1. Swipe down on home screen to reveal quick access panel.
Step 2. Tap Water lock icon.
03-british-how-to-use-galaxy-watch-features
Step 3. To Turn off, press and hold the Home key for two seconds.
04-british-how-to-use-galaxy-watch-features
