Battery draining fast for Galaxy Watch
(Topic created on: 09-02-2022 01:18 AM)
sig_ice
Wearables
Have a Gen1 watch and battery drains really fast even on battery saving. Any solutions for this?
6 REPLIES 6
Wearables
Hi if it's Watch Gen 1 should be around 4 years already right? Recently having this issue only?
renevous
Wearables
In the open market no one able to.change the battery? Cause if go direct samsung... I doubt is going to be cheap for that.. the price may cost almost like getting a new watch... lol
clloh3005
Beginner Level 3
Wearables
I bought a replacement S$20 battery that comes with some free special tools on TB (although abit confusing to get my watch model right). Need to DIY to replace the bloated battery.
renevous
Wearables
Then this rate still reasonable. So long own self replace it and the software still updating everything should be still goog to go
Wearables
Think it would be more worth it to get a Watch 4, 5 or 5 pro than to repair...
Most prob Samsung would not be keeping spare part for Gen 1.
SamsungNantakkumar
Wearables
Hello sig_ice. I am Avinash, from Samsung.
We're sorry for the experience. Can we trouble you to perform the following troubleshooting steps?
1. Restart the watch
- Press and hold the Home/Power button for more than 7 seconds to restart the Galaxy Watch.
2. Check for the Samsung Galaxy Wearable application updates
- Go to Settings
- Tap on Applications
- Select the Samsung Galaxy Wearable application
- Check if the app is in its latest version. Tap on Update if an update is available.
3.
A.) Check for latest software updates on the watch
- Go to Settings
- Select General
- Select Update watch software (The Update watch software option is displayed only when you use the Galaxy Watch without connecting to a mobile device).
B.) Update watch software via phone:
- Galaxy watch app via phone
- select watch model
- General
- Watch software update
- Download and install
4. Back up the data on your watch using the Galaxy Wearable app.
- Launch Galaxy Wearable app
- Tap on Settings
- Tap on About Watch
- Tap on Backup and restore
- Tap on Backup
However, if the issue persists, we strongly suggest you contact our Samsung Care Line at 1800-425-2997 and our experts will be able to advise you accordingly.
