Blood Pressure Calibration (Weak Signal)
(Topic created on: 03-17-2023 01:15 PM)
Goresh
Wearables
I have tried to calibrate the blood pressure function but have been completely unsuccessful.
Shortly after I received the watch, I ran through the process ok but did not have a machine to measure the blood pressure.
I have just tried to calibrate the watch at the doctor's office with a machine but gave up after 5 attempts as it repeatedly failed with a weak signal error.
I have tried over a dozen times at home since with the same error regardless of how tight or loose the band, where it is placed on the arm.
I even tried putting the watch on the inside of my arm to no avail.
The only change between the successful run through without the machine and the attempt with the machine is I updated the software on the phone.
Oh, and the watch refused to accept the PIN last night, (first time I took the watch off to charge) to unlock and I had to do a restart.
Anyone else had problems?
13 Comments
Goresh
Wearables
OK Update
I have restarted the watch and it worked ok.
Unfortunately, I won't see the doctor again for another month now to try the process again.
Wearables
Most chemists will take your blood pressure for free, perhaps you could try your local?
Members_j4euSx5
Wearables
I have the same experience with the blood pressure monitor and the blood oxygen reading neither test completes and each time it is either a weak signal or that I need to move the wat h to a better position for the blood oxygen reading.
It's is a little disappointing considering  devices that cost less than $50.00 can produce consistent results even though they may not be accurate.
Members_oea75uj
Wearables
Exactly my issue with “weak signal”  reading. Still not fixed after switching on and off over a number of days. Very disappointing Samsung.
Graham54
Wearables
Same issuehere. It used to work fine but had to reset my watch after it locked up. Now I struggle to calibrate the BP measurement.... Always says "Weak signal" unless I tighten the strap super tight. Eventually got there but it is not right that it has to beso tight.
Jhawarkavish
Wearables
I am also facing same problem
city35
Beginner Level 4
Wearables
I have the same problem.  At 100% it then says signal too weak.
I think this is a programming problem.  Resolution = Check the signal first and adjust the position of the watch.
You are welcome.
Beryl24
Wearables
My watch 7 is 2 weeks old always week signal tried my daughter's on new watch 7 always reads it at once otherwise mine works perfectly in every other way but won't read my blood pressure why I don't think it's faulty because everything else works.Help
Beryl24
Wearables
Mine never reaches 100 percent only 98
