tates21
08-19-2024 10:08 PM in
Wearables
I've noticed that my left samsung earbuds pro 2 always drains faster than the right earbud. This is even when not in use. I have charged the both buds along with the case to 100% last night. However, upon checking this morning my right still has 99% of its battery while my left only has 20%. I tried checking if there are any software updates available but the samsung wearable app says that my device is up to date. What should I do? HUHUHU i just bought the earbuds last july 2024
3 Comments
SGnthusiast5002
08-19-2024 10:39 PM in
Wearables
Yes, same as my buds. Mine was even worse my left has only 2 or 3% left while my right still has 100%. I don't know why. Is the left magnet weak?
08-20-2024 06:40 AM in
WearablesHello, tates21. I understand how frustrating it can be when one earbud drains faster than the other. Since your earbuds are still under warranty, I recommend you visiting a service center. They can help troubleshoot the issue and determine if there’s a defect or if it’s a software-related problem.
You can find the nearest service center to you here: http://smsng.co/SCLocator-SM 📍
Hope this helps!
Louie7
08-20-2024 10:44 PM in
Wearables
Same as my Iconx.
