Resolved! Solved
Multiple device connections for Galaxy Buds Pro?
(Topic created on: 01-04-2022 05:18 PM)
webfaery
Wearables
Can I connect my Galaxy Buds Pro to multiple devices at the same time e.g., my phone and my tablet?
Thanks.
Deb
jamie122
Wearables
They don't seem to support multipoint, But on samsung devices using one ui 3.1 or later they support seamless pairing on the same samsung account. https://www.samsung.com/au/support/mobile-devices/activate-seamless-earbud-connection/
5 Comments
Wearables
Hi @webfaery,
You can pair the Buds Pro to multiple devices, but they don't support multi-point connectivity (Multiple devices at the same time).
To move from the phone to a tablet, you would need to tap on 'Connect' on the device you wish to switch to.
jamie122
Wearables
webfaery
Wearables
Thanks. I'll have a look at the link.
SamsungLaura
Wearables
Thanks @jamie122!
webfaery
Wearables
Okay. It looks like it won't work with my tablet. It's only using one ui 2.1 😒
Thanks for your help.
