Anto6854
02-25-2023 01:34 AM in
Discussion
I am having trouble with this Samsung device Keyboard. It is behaving erratically such that it refuses to type some letters when touching them. I have to type the letter positively to get it to type. The letter P is a real issue. It often won't type while I touch it several times and it eventually works. The same goes for the backspace key. Any ideas please how I fix this very irritating issue
4 REPLIES 4
satin1cups13
Beginner Level 4
02-25-2023 03:56 AM in
Discussion
Have you tried not using it and living
satin1cups13
Beginner Level 4
02-25-2023 04:16 AM in
Discussion
JJ?
mbckl
02-25-2023 12:01 PM in
Discussion
Can you use a different keyboard from the play store? Try google keyboard and see if the issue persists
Troubadour
02-25-2023 06:15 PM in
Discussion
Google "samsung keyboard sensitivity"
Also check whether your keyboard tapping is central by opening keyboard and choosing a particular key and tapping in different places on the key. Bear in mind the ends of different fingers may tap off central. My right index finger is warped and the right top corner of the finger is what hits the key first.
I don't have an answer for the 'p' problem but borrow a bluetooth keyboard and test if the problem occurs on that.
