BATTERY DRAIN
(Topic created on: 10-12-2019 01:15 PM)
DesmondLum
Galaxy Note
Note 9 seems battery drain like crazy,anyone facing this problem??
27 REPLIES 27
DesmondLum
Galaxy Note
alright thanks,could you please screenshot me your battery information?
k31vin8
Galaxy Note
DesmondLum
Galaxy Note
alright thanks bro,I got it.does Greenify helps alot?
k31vin8
Galaxy Note
a bit?
DesmondLum
Galaxy Note
Thanks!!
haematocrit
Galaxy Note
How long is the screen-on time? What about phone idle? 3rd-party apps are inconsistent when it comes to battery usage, so they can't be used to measure the battery life.
I suggest you to monitor the device idle and screen on percentage.
DesmondLum
Galaxy Note
haematocrit
Galaxy Note
DesmondLum Looking at the photos, that's not bad at all. 10% for almost 3 hours of screen time, 4 percent for more than 12 hours of idle state...
DesmondLum
Galaxy Note
Hmm thanks man.
KitSiu
Galaxy Note
