Note 10 Lite audio problems
(Topic created on: 06-22-2021 06:09 PM)
Gimboy
Beginner Level 3
Galaxy Note
Hello. I just experienced audio problems with my Note 10 Lite. The problem is: the speaker has no audio, but when I insert an earphone, the audio plays fine. I then later noticed that there is a "Playing on Headphones" tag on spotify. So I closed spotify but it looks to be affecting youtube, FB and messenger vids. For sure this is not an Audio Jack problem as the audio plays fine when I insert a headset/ear plugs to the audio Jack. Could this be a system glitch? Please advice as rebooting did not really help
P.S: my note 10 is updated ti the latest software version as it says "Software is Up To Date". Reseting all settings did not help either.
Update: speaker works fine when playing the ringtones in "sounds and notifications" page in the settings app. It seems to be affecting only apps.
5 REPLIES 5
nopee
Galaxy Note
Have you checked if there are debris inside the headphone jack? Try cleaning it with Q-tip (remove most of the cotton)
Gimboy
Beginner Level 3
Galaxy Note
I have put that in mind but what's really weird is the phone speaker works totally fine when playing the notif sounds for the alarm and it's very loud. I just noticed that it only affects apps
nopee
Galaxy Note
Alarm and notifications can still play on speakers even when headphone jack is connected.
TeamGalaxyRene
Galaxy Note
Hey there! Welcome to Samsung Members Community! Explore your new hub for all things Samsung and beyond. Earn the coolest badges and enjoy awesome perks from us by connect with Samsung experts, super-fans, and other Community members for tips on features and how to get the most out of your Samsung product. Should you need technical assistance, don't hesitate to reach us via our TOLL-FREE mobile number #GALAXY (#425299) or via our TOLL-FREE LANDLINE: PLDT Toll free : 1-800-10-726-7864 Globe Toll Free : 1-800-8-726-7864 Standard Landline : (02)8-422-2111 Daily (8:00 AM to 8:00 PM).
Have you resolved your concern yet?
Try blowing hard and sudden on through the speaker holes, earphone jack port/charging port of your device, then test the sounds again. Should the problem still persist, try clearing data cache and rebooting your device. Also try and do a factory data reset.
If none of the aforementioned works, reach us via the hotlines stated above. Stay safe. 😊
PanduTooGood
Galaxy Note
At least yours plays on earphones and headphones.  Mine doesn't put out any sound on both at all
