Note 10 Plus Battery
(Topic created on: 01-30-2024 04:28 PM)
MasterLuke
Galaxy Note
Hello guys! I just wanna ask if some of you did your battery replacement on your own? I am planning to do it. Do you guys have any recommendations?
1 REPLY 1
TeamGalaxyDD
Galaxy Note
Hey MasterLuke,
Replacing a smartphone battery is a pretty advanced DIY project, especially if you're replacing a bloated battery. Here's an iFixit guide for your reference: Samsung Galaxy Note10 Battery Replacement - iFixit Repair Guide
You're going to need a bunch of specialized tools to get this to work, which, if you don't already have them, might end up costing more than getting your device repaired with a service center instead.
Also, you would need to make triple-sure that you're going to be buying a legitimate Galaxy Note10+ battery from Samsung - third party distributors may have counterfeits of the batteries, which are not subject to the same build standards of Samsung factories.
If you do decide to do it though - make sure to be careful!
