Note 20 Ultra Battery Issue
(Topic created on: 09-15-2020 06:47 AM)
royps
Galaxy Note
Hi there Note 20 Ultra user,
Do you have the same issue with the battery? My battery drains crazy. How about you? How long your Note 20 Ultra last?
6 REPLIES 6
Galaxy Note
Note 20 Ultra 5G user here, mine last around 7-8 hours outside using data. But at home/office 8-9 hours with wifi connection. It really depends on the usage too. As I use both sim slots, so it uses a lot of battery. I suggest optimizing your phone to maximize the battery usage. Use Bixby Routines, it really helps.
Arren
Galaxy Note
4-5 hours with gaming on a wifi.
AiBun
Galaxy Note
mine could last for only 3hrs and 30 mins of screen on time. thats from 100% down to 20%. im using wifi at home and usually play gpu intensive game with average 35-50 fps, play some youtube videos at 1080p res, and socmed browsing. your right the battery drains like crazy even in standby mode while wifi is on.
Jed87
Galaxy Note
I normally charge my phone 3x to 4x per day. 🥲
royps
Galaxy Note
That's odd. Hope samsung will soon release an update to fix this.
royps
Galaxy Note
Can't wait for this. Hope this will fix everything!
