Resolved! Solved
Will factory resetting my phone help with the battery drain?
(Topic created on: 12-22-2021 06:35 AM)
SuperLovedandBlessed
Galaxy Note
I've watched a lot of video tutorials on how to save battery etc. I read comments that factory resetting the device has helped some people significantly improve their battery life. What do guys think about that?
SamsungRightCare
Galaxy Note
Hello there! Battery life is highly dependent on how the battery is utilized, and battery life varies greatly amongst devices. The user manual for your device will tell you how long the battery should last. The following tips will show you how to get the best out of your battery in everyday usage and how to look after your battery. You may check out this link; https://www.samsung.com/nz/support/mobile-devices/11-tips-to-extend-and-improve-your-samsung-galaxy-...
Hope to have helped you. Be sure to click " ✓ Accept as Solution" when you find an answer that works for you.  Stay safe and have a nice day ahead!
22 REPLIES 22
Magnaguard
Galaxy Note
Depends on the cause of the battery drain. If the device is old, then the battery is old too. Factory reset won't help with that. If an app is the cause, then deleting that app will help. Factory reset is a bit drastic but it will solve it if that is the root cause of the drain. If all else fails, then yeah fo a factory reset. But be sure of the cause of the drain first.
Galaxy Note
Phone is less than a month old, I don't even use it often because I use my iPad more. I have no social media, only YouTube and sometimes Spotify. I've put most apps to sleep / deep sleep. Power saving mode is one. I don't know what else could cause battery to drain so fast. Any thoughts?
Magnaguard
Galaxy Note
What device is it?
Galaxy Note
Note 20 Ultra 5g Snapdragon Dual Sim
Magnaguard
Galaxy Note
We have the same phone although maybe a different make but the same chip and all. What's your SOT currently?
Galaxy Note
SOT is usually 4 hours? I haven't used my phone lately, since I'm trying to figure out the battery issue. But whenever I watch YouTube tutorials, and read comments, my phone really drains quite fast compared to others after doing all the battery settings like night mode, power saving, dark theme, disable animations, disable edge panel, turn off 5g, turn off or put apps to sleep, use standard mode etc.. I've don't all those but my battery hasn't improved one bit.
Magnaguard
Galaxy Note
Did you check in the Battery and Device Care to see what is causing it?
Magnaguard
Galaxy Note
Do you have the latest update for your device? Try wiping the cache partition first.
Magnaguard
Galaxy Note
It won't work with a headset plugged in. Plug it to a laptop or a PC then do the button combination.
