Battery Draining after 6.1 update
(Topic created on: 07-09-2024 03:15 PM)
Dheeru
I got 24ultra, running fine untill 6.1 update. After the update Battery is draining like anything. Need to charge at least 3 times a day. Pathetic and frustrating. @samsung need to address this asap.
4 Comments
Hi @Dheeru the S24 Series came with One UI 6.1 as new.
Do you mean the issue arose since the June update?
I haven't experienced this issue, so not sure what could be causing it.
You might be best to send an error report to Samsung, using the Members App.
To send an error report:
Samsung Members app > Support > Error reports > select issue category > Describe issue and frequency > Tick ‘Send system log data’ > ‘Send’ in top right.
Dheeru
Hi @Dolgogi, No, I got an update on 26th June. Since then, battery life is terrible.
robmulally
What does it say is using most of the battery? Screenshot bat usage
Hi , have you tried to wipe cache and restart the phone or use "good guardian" app to do a deep dusting after updates. Plus a screenshot of your screen time and apps used will help to find the app which drain your battery
