Battery life of Galaxy S22 Ultra
(Topic created on: 06-26-2023 07:27 PM)
jrnb2023
Is this battery life normal for a two week old recently purchased Galaxy S22 Ultra?
Is it possible to reach two day battery life as advertised?
5 Comments
TeamGalaxyDD
Hey jhanrayb,
I understand your worries about your battery, but here are a few things to keep in mind:
- The Galaxy S22 Ultra was never advertised as having a 48-hour battery. Current battery tech doesn't allow for that, especially with the power demands of this particular phone. GSMArena tested this phone and found it to last around 15½ hours with heavy usage.
- The Battery health monitor on your Settings menu is an estimation of your remaining battery life, and does not take into account how heavy you're going to be using your phone.
- Your battery life will depend on the apps you use, your screen time, which wireless connections are running, and even things such as heat and how many charge cycles your battery has gone through.
To answer your question - at a glance, it doesn't look like you have a problem with your battery right now. You can always run diagnostics on your device through your Samsung Members app should you feel like your battery is malfunctioning.
jrnb2023
Appreciate the clarification, sir @TeamGalaxyDD. I think based on 15 1/2 hour battery life, as tested by GSMArena, my phone is surprisingly really doing well!
TeamGalaxyDD
No worries, glad it's all cleared up. Enjoy your S22U ♥
Lambsauce
Are you using your phone normally or are you deliberately avoiding using your phone, lowering brightness, performance etc? If not, then thats great.
jrnb2023
I use the standard 60hz display option and use adaptive brightness and extra dim only at night. Other than that the usage is normal and i even try turning on my VPN
