Bought a S21 FE about 2 - 3 weeks ago and phone is stuttering and lagging
(Topic created on: 01-03-2023 03:40 PM)
Codyyy
hi so I got the s21 fe 2 or 3 weeks ago and after some use of the phone it's becoming laggy and is stuttering when I click on things I upgraded from a s10 becuse the screen had died and whenever I open the camera especially it lags like hell and also takes a while to take a photo after I press the shutter button I enabled developer settings and checking my RAM usage and it says that 1.8GB of my RAM is being used by "Android OS" and it shows the frequency of it is 100% High and I don't know why it's doing this I've also enabled Auto Optimisation is their anything I can do to help my phone become less laggy? If it helps I'm on the Android 13 One UI 5.0 Patch
9 Comments
Frank55
Don't update your phone. There's already major issues with Samsung's update.
Frank55
I just saw channel7 news saying that if you update you could lose contacts an photo's. So backup your contacts if you update an backup photos
Codyyy
will do
Frank55
A major bug in Samsung's software update.
@Grego1
Don't you have the S21FE?
Didn't you upgrade your phone without this issue?
Frank55
I do. I did upgrade but I always backup my stuff.
andyg77
Beginner Level 5
I find there is a lag as well
DylanU
That'd has happened to my samsung A32 4G and I just backed everything up and did a factory reset then it was working smoothly. Hope you get the problem fixed soon.
