DEVICE OVERHEATING ISSUE AFTER ANDROID 12.0 UPDATE
(Topic created on: 12-25-2021 01:08 PM)
Robbins
How to resolve this issue? I was using Facebook messenger for video call and the device starts heating up. Samsung Galaxy S21 Ultra here.
9 REPLIES 9
Were you using wi-fi or Data? Only asking as I have the s21 Ultra and it does it to mine when I use Data. @Robbins
Robbins
I'm was using e-sim data. Now I'm on WiFi but device is still heating up.
If you tap on the icon at the bottom right hand corner in here (members app) that says Get Help a page will open up, scroll down and click on error report. It should send through your problem to Samsung and hopefully it can be fixed.🤞
Robbins
Just did it. Thank you for help @Jodsta. Merry Christmas and happy new year 🎉
Glad I could help out, hopefully the error report you have sent will let you know what you can do to fix the problem.
Merry Christmas to you too and have a great New Year @Robbins
fadilahrz
Beginner Level 3
Does it work? I have the same problem
The other thing you can try, and the support team may suggest this, is to do a factory reset of the device.
If you do, make sure to back-up your data
Samantha821
I had the same issue after the update, on Christmas day too. First time I've had any issue with the phone. Didn't think much of it until now.
SamsungLaura
Hi @Robbins, as our users have mentioned, I suggest sending an error report via the Samsung Members app for this to be investigated. Error reports are sent to our team to identify any deviations in your device performance, once analysed, our team will get back to you with a response to advise further.
To send an error report:
Samsung Members > Get help > Error reports > Overheating > describe issue and frequency > Tick ‘send system log data’ > Send in top right
