Members_ZvUKZEb
06-01-2022 06:01 PM in
Galaxy SHi there. I used to use the snipping rectangle on my edge panel to select text. I would then get an option to extract text. Now it defaults to Pin/insert.
Any ideas how I reset this to extract text.
Thanks again Mick
1 REPLY 1
06-02-2022 02:31 PM in
Galaxy SHi there, could you please try the following:
Open Edge Panel > Gear icon > Tick 'Smart Select' > Untick other edge panels (if you do not use them) to make Smart Select the first panel.
