01-10-2023 09:13 AM in
Galaxy S- Mark as New
01-14-2023 01:36 PM in
01-17-2023 07:11 PM in
01-20-2023 04:13 PM (Last edited 01-20-2023 04:14 PM ) in
Galaxy SHello @ PhilBurns
I am sorry to hear you are having an issue with your phone. Please follow the below directions to turn easy mode on or off:
You can access Easy Mode in Settings > Display > Easy Mode.
I hope this helped.
Kind Regards,
SmsungClaudette
01-20-2023 07:37 PM in
01-24-2023 03:43 PM in
Galaxy SHello @PhilBurns
I am sorry to hear that this hasn’t solved your issue. Please refer to this link below:
samsung.com/au/support/mobile-devices/using-easy-mode/
If this problem persists, please send me a message back.
Kind regards,
SamsungClaudette
01-28-2023 03:33 PM in
Galaxy SAlso searching for it gives zero results
12-14-2023 11:22 PM in
Galaxy SHi, in case you're still struggling with this.
What helped for me is turning the power saving mode on and off again. Apparently, even though it showed as "power saving mode off", it wasn't fully disabled. Turning it on and off did the trick.
08-27-2024 11:59 AM in
Galaxy SThanks. it worked . just love my Edge Panels. phone not the same without them
09-19-2024 10:21 AM in
Galaxy SLucky you. Also experiencing same problem. I have tried switching power saving mode on and off but still struggling 🤷♀️I don't know what else to do
09-20-2024 08:29 AM in
Galaxy SAlso having these very same issues. Can't turn off dark mode because phone says it can't do that while power saving mode is on even though it is not, and my edge panels are also greyed out. I am definitely not on easy mode. Hope someone can help.
