Ellaah
12-11-2020 09:43 PM in
I have issue on my S20 FE, it will have a fast wireless charging status then it will change to Wireless Charging after 10 seconds?
The seller of my wireless charger has already replaced it but the issue is still the same.
I tried the device care settings then the safe mode but nothing is working.
Anyone experiencing the same issue?
5 Comments
jomz1988
12-11-2020 11:15 PM in
Im experiencing this with cable. the other side of the cable has fast charging and when you flip it over fast charging does not work
12-12-2020 12:50 AM in
Try another cable if it's the same, then you have bring your phone to a service center. If not then you're cable is the problem. 😊
12-12-2020 12:49 AM in
Probably you're fast wireless charger isn't connecting properly with the charging coils at the back.
IvyNatividad
02-16-2022 06:22 AM in
Have you resolved this issue? Or still a problem? I am experiencing it too 😔😔😔
Ellaah
02-16-2022 06:58 AM in
I decided not to use wireless charging anymore since nothing is working
