Gap Between the Screen and Frame of The Galaxy S24 Base Model
(Topic created on: 08-20-2024 02:33 AM)
Pai1995
Is the gap between the screen and frame normal in the base model of the S24? It's small, but it fits the paper, and it's only visible in good lighting or with a flashlight.
The length of the gap is almost one inch.
7 REPLIES 7
TeamGalaxyBianx
Hey there, Pai1995! I understand your concern about the minor gap between the screen and frame on your Galaxy S24. It’s actually a common design feature and usually nothing to worry about. However, if it’s causing you any discomfort, I recommend visiting our service center. Our team will be happy to check it out for you and ensure that everything is working perfectly!
You can find the nearest service center to you here: http://smsng.co/SCLocator-SM 📍
Hope this helps!
Pai1995
I'm just afraid that water might get into it because I tried to put paper on it even though it got in.
Patrik1234
Hello,i have the same thing,did you get any answer about if water goes thriugh and is it normal does evry device have it ?
SagaOtaku
You should be able to notice it when you purchase the device or first unboxing.
Pai1995
You can't see it when you use the phone normally; it is only visible if you look at it side by side or put a flashlight on it. I am only concerned about this is that the water might get into it.
rlgrime
Is it resolved? Did you get in touch with the service centre?
iNico
Any Updates?
