Help me again
(Topic created on: 06-17-2021 09:40 PM)
DenzB
Hello
Ever since i restore factor my phone and recieved my software update, while playing online games still lag what will i do
Magnaguard
There are times the phone lags. There are a couple of reasons.
a. The game isn't optimized for your device. Nothing you can do but wait for the dev to fix it.
b. The app needs more resources than what your phone can handle. Check unnecessary apps that run in the background. Whatever isn't important that gets prioritized in memory handling, delete it. System apps are important. DON'T delete them or put them to sleep.
c. Your internet or data connection **bleep**. Well you know what to do here.
No amount of factory restore will fix these problems. Good luck.
3 Comments
Magnaguard
TeamGalaxyEvflor
Hey, DizzyBone! Have you tried doing what your co member said? I hope it works! If not,  don't hesitate to reach us via our TOLL-FREE mobile number #GALAXY (#425299) or via our TOLL-FREE LANDLINE: PLDT Toll free : 1-800-10-726-7864 Globe Toll Free : 1-800-8-726-7864 Standard Landline : (02)8-422-2111 Daily (8:00 AM to 8:00 PM). We are very willing to assist you. Godbless and enjoy!
nopee
First make sure your phone doesn't get hot while playing. Heat is bad for phones and may affect gaming.
I'd recommend the app 'Game Plugins' on Galaxy Store. It has options for adjusting Graphics Quality, Frame Rate and to monitor Temperature, CPU usage and other game improvement features.
