01-31-2022 08:27 PM in
Galaxy S- Mark as New
01-31-2022 09:21 PM in
02-01-2022 02:09 PM in
02-01-2022 02:07 PM in
Galaxy SHi @ilikecats, I suggest doing a diagnostic check of your device via the Samsung Members app to check your battery health.
To do this:
Samsung Members app > Get Help > View Tests > Battery status
Some other things you can do to assist with battery health is:
1. Close background apps
2. Settings > Device care > Optimise
3. Disable settings in Quick Panel (swipe down from top) that you are not using.
If the issue persists, I recommend for you to head into your nearest authorised service centre with your proof of purchase so that we can take a closer look into this. Please be aware that due to our Privacy Policy, your device may be factory reset before being assessed. I highly recommend backing up your device via Smart Switch, OneDrive and/or Google to ensure none of your data is lost.
For more information on how to back up your device: https://www.samsung.com/au/support/mobile-devices/back-up-samsung-device/
To book an appointment prior to heading in-store or to drop off your device via Australia Post: https://www.samsung.com/au/support/your-service/main
To find your nearest store: https://www.samsung.com/au/samsungstore/
02-01-2022 06:38 PM in
02-01-2022 09:18 PM in
02-01-2022 06:47 PM in
