Help
(Topic created on: 02-13-2021 09:42 PM)
GerardJethro
What will happen if Im going to delete the hidden files?
RawAndReal
If these are system hidden files, then most likely they were hidden by design as deleting them might cause some apps not to work as they arw intended to be. but if these are hidden files that were personally tagged as hidden, then, it should be ok deleting them.
5 Comments
RedS10Plus
same question
GerardJethro
what will happen if i delete the hidden file?
polpogs
ui 3.0?
system files can't be accessed using the default files.
most of those you are seeing are temporary repositories by apps.
if you delete them and you didn't get any restrictions, you should be fine
behold, those folders and files are going to show up again the moment you access apps' features that create those
soo, i dont know. 🤣
RawAndReal
i don't know Sir but I think you're referring to temporary files?
RawAndReal
