Incoming call issue
(Topic created on: 03-03-2023 12:58 PM)
Ajay1997
I am having some weird issues with my Galaxy S22 ultra. People are not being able to call me. The call either fails instantly or sometimes, the call fails after 2-3 rings. I am not sure when did it start happening. The outgoing calls work fine. Need help fixing this.
21 REPLIES 21
Can you put your sim card into a different phone and see if the issue continues?
You can also try resetting the network settings.
SamsungClaudette
Hello @
Thank you for your suggestions.
Kind Regards,
SamsungClaudette
Troubadour
Telstra has different 5G APN settings so Google that. To look up your settings go to Settings, Search, Access Point Names. If you try to change make sure you have written down your current settings ON A SEPARATE PIECE OF PAPER, 100% correct, caps, spacing, in case you have to revert..Also Google "Call forwarding" in case you have accidentally set that. Consider setting your phone to 4G , LTE, in case network coverage is an issue. Load an app AUS Phone Towers to check coverage.. If your phone is on 5G incoming calls may not find it, whilst for outgoing calls your phone will move down to 4G if 5G isn't available.
As a separate issue Google on "your ISP name Wifi Calling," if on Telstra, Optus, Boost, Vodafone as this allows calls to come in via wifi if you are logged in.
peglegreg
A new sim card my fix it, it happened to me a few years ago, and was fixed by a new one.
Greg
SamsungClaudette
Hello @Ajay1997
Could you please refer to @ comment and let me know if it worked.
Kind Regards,
SamsungClaudette
Ajay1997
Tried resetting the network settings didn't work.
Checked each and every settings on the phone itself, nothing wrong.
I got myself a new sim card yet the issue exists
Ajay1997
However, I found a solution. When I set the network mode to 3G/2G the issue disappears but this solution is not feasible as the mobile data speed becomes slower.Screenshot_20230309_235204_Call settings.jpg
Ajay1997
I encountered about 5 person in my circle with a samsung phone facing the same issues. Hoping a software update might fix this.
Ajay1997
Is anybody else facing the same issue? I recently got a software update and I was hoping that the update might fix the issue but nope it still exists @SamsungClaudette
