Is my battery damaged?
(Topic created on: 11-28-2023 06:48 AM)
JulianSounds
I left my phone charging for four and a half hours overnight while it was switched off. Is this a practice one should avoid to reduce the risk of battery damage? The phone wasn't hot when I unplugged it.
6 Comments
jason1626
Before bedtime, you should turn on protect battery, which charges maximum up to 85%, and it won't damage the battery at all. But leaving switched off while charged is risky to damage the battery if you do
Mostly.
JulianSounds
Thank you. 👍
How does one know when the battery is damaged?
What are the signs?
Troubadour
Either the battery runs down very quickly or it only charges to a certain level
JulianSounds
Thank you. 😊 👍
jason1626
To check the battery capacity, go to the setting, then about the phone, then battery information, u will see that battery capacity that you have now.
JulianSounds
Thank you. 👍
