monmonami
03-07-2021 02:39 PM in
How much should the cost be for an S10+ LCD replacment? Got a crack on the screen and white line on the screen on the impact.
Solved! Go to Solution.
RawAndReal
03-07-2021 03:24 PM in
i believe it ranges between 4k to 6k depending where you want it replaced. if you're leaning towards the safe side but comes with a premium, I'd say go to a Samsung SC.
RawAndReal
