need help please with Gemini
(Topic created on: 07-14-2025 12:24 PM)
mark_99
Hi,guys Do you anyone know how to change Gemini sitting to make call or play songs when my phone lock because always asking to unlock the phone!
2 REPLIES 2
There should be an Option under the Gemini settings that says "Gemini on lock screen" go into that setting and make sure it's ticked.
Oceean
Open the Gemini app: on your Android phone
Tap your profile picture or initial: at the top right of the screen.
Tap "Settings" .
Tap "Gemini on lock screen" .
Turn on "Allow calls and messages without unlocking": (or a similar option like "Make calls and send messages without unlocking").
Ensure the "Phone" app extension is enabled: in Gemini settings if you want to make calls.
You may also need to ensure
Open the Gemini app: on your Android phone or tablet.
Tap "Settings" .
You may also need to ensure Gemini has the necessary app permissions, particularly for "Phone" and "Microphone," in your phone's Gemini has the necessary app permissions, particularly for "Phone" and "Microphone," in your phone's
