Need Help with How to remove Call record on dial pad
(Topic created on: 08-06-2025 03:50 PM)
Members_jovilady
Noticed this since update and i dont like it.  Can anyone tell me how to get rid of this i dont want it as sometimes gets turned on when on a call if my face hits it by accident so annoying and embarrasing if on a call to someone you dont know
4 REPLIES 4
StarDust88
I think that's your call assist enabled.
Open the phone dialer app, tap on the 3 dots on top right, then tap on settings > text call, and you can disable it there.
hi stardust it is disabled there and i dont think its that its only displayed when your actually on a call  and if you accidently hit with  your cheek while on call turns on and a voice says this call is being recorded you then can switch back off its just annoying i just want it off the screen notice this since  software update hopefully it gets fixed in next update
Unfortunately, there currently isn't any official way to disable that feature.
You could try this, when you start a phone call press the home screen button so you don't accidentally press it.
Or use a different phone dialer like the Google Phone app if you really have lots of accidental recordings.
