Notification sound
(Topic created on: 03-13-2025 03:26 PM)
Woroud
For some reason, I can't change the notification sound for each app on my S25 Ultra. All notifications have the same sound; even Snapchat doesn't have its normal notification sound. Are you experiencing the same issue, or am I missing something?
You can do it like this:
Open Settings-> Notifications-> Advanced Settings.
From here, scroll down and turn on Manage notification categories for each app.
Return to the main Settings screen, scroll down and select Apps.
Select the app you want to customize.
Tap on Notifications.
Tap on Notification categories.
Select the specific notification type (e.g., new messages, comments, etc.).
Choose the desired sound from the available options.
I hope that helps.
