Optimize battery usage missing *battery drain issue solved
(Topic created on: 01-08-2023 03:52 PM)
Stanley3
Using s21 ultra Asan yang settings bat hindi makita? Lahat ginawa ko na inoff ko na data at sync pati location naka deep sleep na halos lahat pero wala talaga pag asa oneui5 lamon sa battery sobra. Di ba yan pwede downgrade to oneui4? Nakakaumay eh, matulog ka lang pag gising mo 30% bawas sa battery. Submit report wala naman response, tiniis ko nang 2 months simula nilabas update then 1-2weeks before from now nag factory reset pako kase last resort na talaga kaso same padin oneui5 talaga culprit tama sabi ng mga beta testers may abnormally high battery consumption na di nawala kahit official release na.
From samsung faq
Screenshot in my phone
11 REPLIES 11
YhobS24ultra
Search mo na lang mas madali
YhobS24ultra
Nasa battery and device care
YhobS24ultra
EtoScreenshot_20230109_101740_Settings Suggestions_1000000050_1673230660.jpg
jdvader
Hello, background usage limit option is your only resort on this. Set to deep sleep, the app you don't want to run in background. This app will only work if you open it.
If occasional run, set it to sleeping apps only. Look for Battery and Device care. Hope that helps.
TeamGalaxyRene
Hello Stanley3,
Sorry to hear that, after trying all the possible do-it-yourself troubleshooting, it seems that none of these were able to solve your device problems and we really feel what you feel.
We recommend that you bring it immediately to the nearest Samsung Authorized Service Center. Rest assured that our Samsung Engineers/Technicians are competent to assess your device and offer solutions to restore it up to optimum performance.
https://www.samsung.com/ph/support/service-center/
For more assistance, you may contact us on our online Samsung support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or contact our Samsung direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
Stanley3
How long will it take for them to check? Can it be repaired on the same day or it need to stay there for a day or two?
TeamGalaxyRene
Hello Stanley3,
Thanks for your inquiry.
It will depend on the outcome of the assessment and the extent of the device's issue for repair, user's confirmation, parts availability, and the post-repair observations.
Stanley3
Nvm, after days of trial and error in tweaking settings ive solved my own problem again 😂 its now normal. Only drains 6-8% overnight compared to 20-30% before. And even the estimated is now longer than the actual because it did improved a lot. Before when i woke up at 11:30am my battery is only 40-45% now its 90% woohoo... Even the phone and remote support using smart tutor didnt fix my problem. Case closedScreenshot_20230113_123159_Device care_1000000692_1673584319.png
Supermond
how po? pano ginawa mo sa settings sir?
