Pause USB Power delivery while in DEX
(Topic created on: 07-21-2023 01:52 AM)
Sipahi061
Beginner Level 3
Is it possible to use the pause USB power delivery feature while in DEX mode ? I was unable to do so, if not I think that would be a great feature to reduce heat and preserve battery life, since while in DEX phones are typically plugged in for hours on end. If not is it known if there are any future updates or plans to get pause USB power delivery feature within DEX mode ?
2 REPLIES 2
Hi~ are you connecting it to a monitor only? or a laptop? do you know that you can use Samsung Dex wirelessly? As long as it is connected to the same wifi network.
Shayan2
Beginner Level 3
Yes that would be a great feature and turn your phone into a real laptop, I  hope that Samsung consider this feature and add it to next updates
