Resolved! Solved
Random Notification Sound s21 Ultra
(Topic created on: 02-22-2022 05:12 PM)
Noxxie
Hi guys, wondering if anyone can help with this.
I normally have my phone on vibrate 24/7 but have recently been using it with normal 'Sound' on.
My notification sound keeps going off even though no notification shows, not in the panel either. It's really annoying and I don't want to be putting my phone on vibrate all the time again because of it.
I have checked on GoodLock via Nice Catch to see what the vibration notification is and its telling me it's an Accessibility notification. I have gone through Accessibility and have no idea what's triggering this notification sound.
(Just to note, it's my notification sound going off not a system alert sound)
Any help would be appreciated if you have had this same issue.
Cheers.
SamsungLaura
Hi @Noxxie, that's odd. I suggest resetting your phone settings and seeing if this helps.
To do this:
Settings > General Management > Reset > Reset settings
4 REPLIES 4
Hamboy
Do you have notification reminder turned on?
Noxxie
Yeah I do because I want it on for my messages I don't see straight away. I guess that might be the only fix tho haha.
SamsungLaura
To do this:
Noxxie
Thank you. This worked, specifically 'Reset accessibility settings'. Didn't even know that was a thing.
