S22+ Bluetooth & wifi issues
(Topic created on: 11-24-2022 01:49 AM)
MattR29
Has any one else encountered issues with their Bluetooth function not turning on? Same with wifi? Wifi then randomly turns itself on and then turns off on it's own. The phone was purchased in July 2022.
Very frustrating when trying to run a business.
2 REPLIES 2
s_amsungerika
Hi @MattR29,
I'm sorry to hear you're experiencing this issue with your device. Would you be able to follow the steps below and see if this helps?
Reset network settings [Settings > General Management > Reset > Reset network settings > RESET NETWORK SETTINGS]
I would recommend clearing data from the Bluetooth app in your phone's settings. To do this, click on Settings > Apps > click on the symbol next to the Your apps heading > toggle on Show system apps and click Okay > scroll down and click on Bluetooth > Storage > click to Clear cache and Clear data.
If resetting the network doesn't help, please boot your device into Safe Mode and see if you're able to enable Bluetooth.
Hold power > restart > hold volume down until lock screen
You can tell if you are in Safe Mode as it will be written in the bottom left corner of the screen. If you can see that there is no longer a problem in Safe Mode, then you must have installed an app which is interfering with the phone's functionality. You will need to identify and remove the third party app before you are able to use the phone functionality again. To exit safe mode, please restart the phone.
However, if your Bluetooth still does not turn on in Safe Mode then it would be best to visit your nearest Samsung Studio to have your device booked in for assessment by our qualified technicians. If you need help finding your local store please either visit: https://www.samsung.com/au/support/your-service/main or call our Customer Support team on 1300 425 299 (option 2).
Let me know how it goes.
MattR29
Hi Erika, thanks for your reply. I tried to clear the cache and data for Bluetooth but the button was shadowed out so I couldn't.
I did however reset Network settings and it seems to have worked for the moment. I'll check it again in the morning when I need Bluetooth.
