S22 Ultra Ring Volume/Routines
(Topic created on: 03-02-2023 06:35 PM)
derkleia
Hi all,
I have been using a Sleep Routine for a few months that modifies settings on going to bed and then changes them back when I am due to wake up each day (7 days/wk).
Since the recent software update One UI version 5.1, Android 13   I have been having a problem.
Each day when I wake up my phone volume option remains muted so I change it to unmute but my ringtone is still set to a volume I can hardly hear and I have to set it back to maximum?   I have made a few changes to the standard sleep routine to adjust volumes but not to these levels.  I have also set up an exclusion for family members.   Everything works fine except the values used when the routine ends in the morning.
Anyone have any ideas on resolving this issue?
2 Comments
derkleia
Hi again, I found that there was a settings conflict between Do Not Disturb mode and the Sleep Routine. While the settings conflict didn't cause the problems you might expect they did cause Unspecified Results. It's not very intuitive so take care how you use them if you use both functions.
Gjames57
If whoever wrote that was from Samsung they should mention how to be careful not just say it. My phone is constantly turning down the ringtone and then I can't find the phone. It turned it down I turned it up and it went right back down again the next time I turned it up it stayed up for now
I should say unless you're in some kind of sleep mode your ringer should be able to stay locked. But mine turns itself down in the middle of the day it's too easily done at best. Please fix
