S24 FE: One UI7 Battery Issue [SOLVED]
(Topic created on: 05-12-2025 06:23 AM)
Yael_101
About 2 weeks ago after my phone updates from 6.1 to 7, I noticed that battery drains faster than before.
In my opinion this might be because the system suddenly updates from Android 14 to 15 and some of the old processes still running on the backgound.
Just wipe the cache partion, this will solve the issue.
 1. Connect your phone to any laptop then restart ur unit via USB then off ur cp
2. Press power button and volume up [hold until Samsung logo boot] then release
3. Interface boot will change. Using the volume buttons, navigate to "wipe cache partition" press power button to confirm.
4. Once done, navigate to restart.
4 REPLIES 4
RayzerX
Will try this one if will work on my S24 FE
Yael_101
Did it work? Cause my unit is way more better than before😊
RayzerX
Hindi ba sya pede kahit sa normal outlet lang iplug? Need ba talaga sa laptop para makapag wipe cache?
Yael_101
Havn't tried yet na direct sa charging brick.
