S25 Battery Draining Too Fast
(Topic created on: 04-11-2025 01:17 AM)
thissa
Hey guys, just bought an s25 and it's battery has been not good. This is my first time using a flagship samsung so I expected a lot from this device. Everything's been great except the battery. I don't play games or use snapchat. It's just mainly whatsapp, instagram and youtube and google.
I have even implemented the battery protection option to 90 percent.
4 Comments
How long have you had the device?
It's common for new devices to take between 1 to 2 weeks to go through it's optimisation and learning process, depending on how much data was transferred from the previous device.
thissa
Even I thought it was because of that, but now it's been a month
AlyAly
That's normal it's running an AI and also that screen is very power hungry. Maybe have a look the settings and try to reduce or turn off power hungry settings. Such as Samsung Personalisation, WQHD+ res quality, turn on power 🔋 sav mode in battery settings, and 5G services. Maybe just choose 5G mobil connection if you like. Also make sure you turn off auto feedback send reports blah blah these stuff cos they keep constantly running in background.
thissa
I switched from 5g to 4g and then set device performance to light as well. Only thing I haven't changed is the display refresh rate.
