LovelyLove27
Beginner Level 4
03-17-2025 12:30 PM in
Does anyone know to to change the camera sound to the old shutter sound rather than the current one or if there will be an update? Thank you.
Using S25.
Solved! Go to Solution.
_nok_
03-17-2025 05:47 PM in
Is your "Motion Photo" enabled or disabled?
They have different shutter sound depends on the setting.
If On, it have this "tutung" sound 😅
If Off, it's the normal "kachick" sound.
3 REPLIES 3
_nok_
LovelyLove27
Beginner Level 4
03-17-2025 05:53 PM in
Thank you so much! Yes, I did have motion on. Hate that tutung sound lol. Have turned it off.
_nok_
03-17-2025 06:04 PM in
Noice!
Kindly accept this as solution in case for others.😀
