Vibration Problems
(Topic created on: 08-18-2024 05:39 PM)
MrBBear
Has anyone here recently or previously had problems with their phone vibration stooped working. I know recently I had a security update on my Samsung Galaxy S23 Ultra so not sure if this has caused the issue, but my phones vibration has stopped working even when I pull out the Spen it just does vibrate. Thank you.
20 REPLIES 20
StarDust88
MrBBear
It's definitely on
StarDust88
What do you mean by ON, it should be OFF
MrBBear
So for call vibration to work on my phone it needs to be Off does it, seriously?
StarDust88
I was saying make sure your phone isn't on mute, then you said "it's definitely on".
MrBBear
Oops my apologies read wrong no it's definitely not on mute on vibrate mode, I've even increased the vibration strength, tried all the different vibration settings no luck, seems to of happened after the recent security patch update. Not only that is I can't even boot it access that screen where you home down the power button and the volume up button to go and try clear the cache, just doesn't even boot into it, weird.
StarDust88
Oh, have you tried restarting the phone?
MrBBear
Yes few times. How I found out about this few days ago when I removed my Spen from my phone there was no vibration, I normally don't use the vibrate apart from the removal and insertion of the Spen, so this is how I found out
StarDust88
Oh, that's a bummer.
Let's hear what the other members have to say. 🤔
