Vibration Problems
(Topic created on: 08-18-2024 05:39 PM)
MrBBear
Has anyone here recently or previously had problems with their phone vibration stooped working. I know recently I had a security update on my Samsung Galaxy S23 Ultra so not sure if this has caused the issue, but my phones vibration has stopped working even when I pull out the Spen it just does vibrate. Thank you.
20 REPLIES 20
MrBBear
Might have to reset my phone not looking forward to it, I'm trying to clear the cache as well but just can't boot into that screen not having any luck at all.
Have you tried testing the vibrate using the Diagnostic?
It's here in the app - Support > Phone Diagnostics
Nardip
There are 2 vibration tests to perform, one tests call vibration, the other tests notification vibration1723980496008.jpg
So vibration is working in diagnostics? But not when you are using your phone like notifications?
Nardip
Mine is working in diagnostics ( have S23 Ultra and updated Aug 24 security patch) and also both in calls and for app notifications.
Could "Do Not Disturb" be set on ur phone ?
🤦🤦🤦 my bad. I thought you're OP 😅 that's why i asked that question.
MrBBear
I've checked the DND and it's switched off
MrBBear
No vibration does not work on phone nor on diagnosis
MrBBear
No not working in both
MrBBear
Yes I have and no luck at all
