Wifi connection
(Topic created on: 12-16-2022 08:47 PM)
Volam
I'm using S21 ultra for over a year. Recently I started having a problem with wifi connection. It keeps disconnecting and reconnecting. Don't know what to do. Any help with this problem?
3 REPLIES 3
How to fix network connection issues on Samsung Galaxy S21, S21+ or S21 Ultra
1. Turn airplane mode on and off The Airplane mode trick basically works by turning Airplane Mode on for a few seconds and then turning off again. ...
2. Forget and reconnect to network ...
3. Toggle SIM off and on ...
4. Disable 5G ...
5. Reboot your phone and router ...
6. Reset network settings ...
7. Update software ...
Dummy01
Beginner Level 4
Did u get problem fixed
Samsung_Ruby
Hi Volam, if the above doesn't work I recommend sending your device to one of our service centre's to get check - Thanks, The Samsung Team
