Resolved! Solved
Wireless Charger
(Topic created on: 01-04-2022 11:52 AM)
Kove1972
I have recently purchased the Standing Wireless Charger for my Galaxy S20 FE.  According to Samsungs online shop, I should be able to "easily toggle off the fan and dim the LED lights through your phone".  Is this done through an app?  And if so, what is the app and where do I find it?
SamsungLaura
Hi @Kove1972, this feature works by turning off the wireless charging at a set time and subsequently stop the fan and LED.
To use this feature:
Settings > Device Care > Battery > Charging > Fast wireless charging > Toggle on 'Turn off as scheduled' > Set a preferred time to stop charging.
6 Comments
Settings>Advanced features>Accesories
Tap on "Fast wireless charging". If fast charging is enabled, you can set a schedule to turn it off which will reduce the fan speed/noise and dim LED. That's the extent of controlling the fan and LED from the phone.
I found this on another country's Samsung Members, good Luck!
Kove1972
There isn't an Accessories menu within Advanced Features.  I'll keep messing around with the phone and see if I can find something.
Thanks for trying though, I really appreciate it.
Try searching in, Settings/Battery and device care/Battery.
From here scroll down and check the settings for charging listed here (wired & wireless).
Hope that helps.
SamsungLaura
Kove1972
As far as I can tell the fan isn't running which is why I'm trying to find the app to toggle it on - especially during summer.
SamsungLaura
Hi @Kove1972, the fan should be running by default when you are using Fast Wireless Charging. Turning this off, as mentioned above, will turn off the fan and charge it at a slower rate.
