Facing high battery drain issues? Try these simple hacks!
(Topic created on: 11-27-2023 08:47 PM)
Others
Fast-paced battery drainage doesn't mean poor battery health. There might be other reasons which you can solve to obtain good battery life.
Solutions:
🔋: Turn off Wi-Fi, Bluetooth, NFC and other connectivity options if you are not using them.
Swiping down on the Control Menu turn off connectivity options
🔋: Optimize your battery via Device Care
Settings > Battery and device care > Optimize now
🔋: Turn on Power saving
Settings > search power saving
🔋: Dim the screen brightness setting
Swiping down on the Control Menu, toggle the brightness slider to the left
🔋: Turn off the Always On Display
Swiping down on the Control Menu, toggle off the Always On Display icon
🔋: Remove Live Wallpapers
Use regular Wallpapers, the simpler the better
Try these simple hacks to get a much better battery life and be able to use your mobile device a lot longer than before.
📸: Galaxy Z Flip4
3 REPLIES 3
danesaints
Others
ganyan ginagawa ko + dark na rin gamit kong wallpaper. malakas rin maka drain pag light ang wallpaper
Others
Yeah.. +1 on using dark wallpapers. Nagkataon lang din na mas gusto ko yung darker themes as it compliments dark mode.
Others
Back when I was still using a J7, I've already turned off notifications for social media apps. This helped a lot!
