NormanKadz
07-05-2022 07:46 AM in
Others
My phone is not charging!pls help.
4 REPLIES 4
butete
07-05-2022 07:52 AM in
Others
check the cable
Khaled75
07-05-2022 08:08 AM in
Others
What phone are you using? Is the cable damaged?
Ivan_smith_051
07-05-2022 10:32 PM in
OthersWhich phone are you using? Is there any problem with the cable? If there is no defect in the cable then kindly show your phone charging socket to your near mobile phone shop asap!.
SamsungRightCar e
07-24-2022 08:26 PM in
OthersHi NormanKadz,
Hope you can select the best solution to your inquiry, please. Thanks guys, you're great.
