FRAME TV Remote not charging
(Topic created on: 02-11-2023 08:58 AM)
Jane8
TV & Audio
I have a FRAME TV bought in December of 2021.  I am recently getting a message that my remote battery is extremely low and it needs to be recharged.  It has been solar charging for 1 year with no issues until today.  I've left it according to the directions with the solar panel facing up for more than 8 hours and it still shows as 10% charged.
Do I need to replace the remote or is there something I'm missing?
16 Comments
Kiwi8287
TV & Audio
Time to change the remote
Cass14
TV & Audio
I did overnight, but no change in battery %.
Cass14
TV & Audio
I am having the same problem with the same age TV.  I tried charging the remote with a USBC cable over night and the remote still only has 6% battery.
SamsungClaudette
TV & Audio
Hello @Jane8
I’m sorry that you are having issues with your Remote.
 I suggest you try some of the solutions listed below:
  1. Make sure that you have entirely removed the film that is inserted in the bottom of your Samsung Smart Remote.
  2. Make sure that your Smart remote is not disconnected from your TV.
  3. Your batteries might need to be charged more or replaced
  4. While pointing your remote at the screen. Press and hold play/pause and return buttons at the same time for 3 seconds. Your TV will begin syncing with the smart remote.
Kind regards,
SamsungClaudette
jenniferellen
TV & Audio
I am having the same issue, and have tried all of the above. Can you please advise as to what I can do to get the remote charging again?
SamsungClaudette
TV & Audio
Hello @jenniferellen
I am sorry that you are also having this issue. I would like to look into this for you. If you could send an email through to members.au@samsung.com I will have this escalated for you.
Subject Title: SamsungClaudette – What I can do to get the remote charging again?  <----Please post this in the Email Subject as well as your community handle.
Name
Email
Contact Number
Preferred Call Back Time
State of residence
Model
Serial Number
Product Issue
Kind regards,
SamsungClaudette
Moozz
TV & Audio
I'm having same issues with my remote purchased 65" July 2022. Spent last month or prob more, having to constantly plug in to recharge. Lucky if it lasts an hour after fully charging by use and won't solar charge at all 😡
And yes, I've done all things suggested above...
Do I need to contact Samsung for replacement or return to a store? I bought online and their site says bring in but how will they replace unless they take one from a new TV???
SamsungClaudette
TV & Audio
Hello @Moozz
Subject Title: SamsungClaudette – I'm having same issues with my remote purchased 65" July 2022 <----Please post this in the Email Subject as well as your community handle.
Name
Email
Contact Number
State of residence
Model
Serial Number
Product Issue
Kind regards,
SamsungClaudette
Monday42
TV & Audio
Same issue. Please help!!! My TV is now useless!
