Frame TV remote won't charge
(Topic created on: 04-17-2022 07:07 AM)
Members_MgJP0pn
TV & Audio
My 2 month old frame TV's remote will not charge via plug in or solar. We luckily set up a phone to be a remote. Any ideas?
41 Comments
SamsungLaura
TV & Audio
Hi there, that's strange. Are you able to visit the below link and try our Troubleshooting steps listed below?
https://www.samsung.com/au/support/tv-audio-video/use-and-charge-solar-powered-tv-remote/
Monday42
TV & Audio
I am having the same issue as well. Won’t charge via solar and after it charges with UBS it lasts less than a day. I can no longer use my TV now as it won’t hold a charge now. Please help!
SamsungClaudette
TV & Audio
Hello @Monday42
I am sorry that you are also having this issue. I would like to look into this for you. If you could send an email through to members.au@samsung.com I will have this escalated for you.
Subject Title: SamsungClaudette – Won’t charge via solar and after it charges with UBS it lasts less than a day <----Please post this in the Email Subject as well as your community handle.
Name
Email
Contact Number
Preferred Call Back Time
State of residence
Model
Serial Number
Product Issue
Kind regards,
SamsungClaudette
Hbills89
TV & Audio
Hi Claudette can I do this as well? My frame tv remote is not holding any charge. Purchased in Jan 2024. Only works when it is plugged into the usb. Thanks
Phil4
TV & Audio
Hi - I have a 2021 Frame TV and my remote will not charge anymore.  Even after plugging it in by USB-C for 4 hours, the battery doesn't seem to hold a change and I get the below messgae.
Pls help.
MonaLisa2
TV & Audio
I'm having the same issue, once charged it quickly runs out. I bought a 3 meter USB-C cable to keep it connected to power while using it so it doesn't run out.  Would have preferred a battery operated remote. The phone remote is a good idea though.
Is there an option to buy a battery operated remote separately and use it with the Frame TV instead of the solar powered one?
SamsungLaura
TV & Audio
Hi @MonaLisa2, could you confirm which TV model you own for me to look into this?
E.g The Frame 2020, 2021, 2022 model.
fstbrkGP
TV & Audio
Same issue 2022 version
SamsungLaura
TV & Audio
Hi @fstbrkGP, can you try the following:
- Restart your TV by switching it off and unplug your TV from the power outlet for a minute. Then re-plug your TV back in and test whether the remote is responsive
- Hold the Back and Play/Pause buttons simultaneously for at least 5 seconds or until a message appears on your TV indicating that the remote is now connected. Test to see if your remote is responsive
- Point the remote towards yourcameraof your mobile phone and press the power button
- If you see the infrared light, turn on your TV using the power button on the TV directly. Then, try controlling the TV again by pointing the remote directly at the Samsung logo.
