04-17-2022 07:07 AM in
TV & AudioMy 2 month old frame TV's remote will not charge via plug in or solar. We luckily set up a phone to be a remote. Any ideas?
07-31-2023 12:32 PM in
TV & AudioHi,
I’m having the same issue with The Frame remote not charging or holding charge.
TV was purchased in November last year and I am currently using the Smart Things Remote Control to operate the TV.
Is there a solution to this issue or do I need to send an email to @SamsungClaudette?
Thanks!
09-13-2023 07:23 AM in
TV & AudioI am having the same problem, the remote runs out of battery. I am conveniently 1 month past my warranty... looks like they made the perfect remote ;/
09-14-2023 09:44 AM in
TV & AudioHello @patrickdholman
I am sorry that you are also having this issue. I would like to look into this for you. If you could send an email through to members.au@samsung.com I will have this escalated for you.
Subject Title: SamsungClaudette – Remote runs out of battery <----Please post this in the Email Subject as well as your community handle.
Name |
Contact Number |
Preferred Call Back Time |
State of residence |
Model |
Serial Number |
Product Issue |
Kind regards,
SamsungClaudette
10-12-2023 02:05 PM in
TV & AudioI can see that lots of people are having the same issue as me, whereby my SAMSUNG BN59-01391B Solar Cell Remote (White) for my Frame 2022 TV has not held charge properly from day 1. Can you please help out Claudette? Note I have also sent an email into members.au@samsung.com.au already with the details you suggest everyone else to complete, proactively.
11-16-2023 08:01 AM in
TV & AudioI am also having the same issue. My remote won’t work without having it plugged in a charger.
11-17-2023 01:19 PM in
TV & AudioHello @Johbi
Subject Title: SamsungClaudette – My remote won’t work without having it plugged in a charger <----Please post this in the Email Subject as well as your community handle.
Name |
Contact Number |
Model |
Serial Number |
Product Issue |
Kind regards,
SamsungClaudette
11-23-2023 04:55 AM in
TV & AudioI am also having the same issue. My remote won’t work without having it plugged in a charger. It is a 2022 model Frame.
11-24-2023 02:08 PM (Last edited 11-24-2023 02:08 PM ) in
TV & AudioHello @MGB1
Name |
Contact Number |
Model |
Serial Number |
Product Issue |
Kind regards,
SamsungClaudette
01-16-2024 08:55 PM in
TV & AudioI am having the same problem with my 4 month old frame TV, remote won't charge, no troubleshooting steps help at all, its just dead... How do I now use this expensive TV?
01-16-2024 09:45 PM in
TV & AudioSo mine also failed within a few months, which is terrible as its a common issue. Unless you have registered with smarthings application you can't use the TV until you get a new remote for around $130. Samsung may provide one free of charge if within warranty, but it will take 14 business days to get to you if you are lucky. For a very expensive TV this is a major design flaw and Samsung should do the right thing and replace the remote free of charge proactively and update so no more issues, otherwise the TV is basically useless.
