Need suggestion for Soundbar for model UA60KU6000WXXY
(Topic created on: 10-09-2021 04:42 PM)
BCham
TV & Audio
Hello,
I'm planning to buy Q series home theatre for my Samsung TV (2016) model UA60KU6000WXXY. Can I get true dolby atmos experience?? As I heard TV models prior 2016 may not support dolby sound. Want genuine advice as q series is not that cheap. ;)
8 Comments
Protonumus
TV & Audio
Connectivity
HDMI In No
HDMI Out 1
HDMI ARC Yes
HDMI CEC Yes
Optical In 1
BluetoothYes
Bluetooth Codec SBC
Bluetooth Multi Connection No
Wi-Fi Yes
USB Music Playback No
One Remote Control Yes
Bluetooth Power On Yes
Chromecast Yes
BCham
TV & Audio
As I have 2016 model, my question is will that be compatible with my TV?
Protonumus
TV & Audio
It said, you can use the Digital Audio Out (optical) to plug in sound bar and speakers.
TV & Audio
Dolby Atmos was introduced around 2016, I think.
Protonumus
TV & Audio
Additional, information on what you can do:
Control an external device connected via Anynet+ (HDMI-CEC) with the remote control.
You can use the TV's remote control to control external devices that are connected to the TV by an HDMI cable and that support Anynet+ (HDMI-CEC).. Up to 12 devices can be controlled by the one remote control; however only 1 Home Theatre System can be controlled over Anynet+ at a time.
Anynet+ can't be used with incompatible (ie. not HDMI-CEC enabled) devices, and some HDMI cables may not support Anynet+.
Anynet+ is enabled on the HDMI ports on most Samsung TVs manufactured after 2008.
BCham
TV & Audio
Thanks alot for info.
