S95D wall mount M8 screw length
(Topic created on: 06-15-2024 06:14 PM)
Members_moksg1e
TV & Audio
The wall mount I have has screws that even with the supplied spacers are a bit to long for my new S95D
Anyone know what length screw I should be using on my S95D
4 Comments
Protonumus
TV & Audio
For mounting your Samsung S95D TV, you should use M8 screws.
The length of the screws can vary depending on the thickness of your TV's back panel, the depth of the wall mount bracket, and any spacers used.
Generally, screws between 1.5 inches to 3 inches (approximately 38 mm to 76 mm) are appropriate.
If you have spacers or a particularly thick mount bracket, you might need to adjust the length accordingly.
It's always a good idea to check the specific requirements in your TV's manual or the wall mount instructions.
Vger70
TV & Audio
the installation instructions state M8 with only 5-6 mm in the TV. So I would use washers or spacers so only 5-6 mm or 1/4” of threads extend past the bracket into the TV.
s_amsungsonny
TV & Audio
Hey there,
Here is the installation guide for the Samsung S95D TV - there is some information on there regarding the screws!
https://downloadcenter.samsung.com/content/EM/202401/20240121034101001/BN68-18053A-00_IG_Y23%20S95C%...
Darkwolf_99
TV & Audio
The instructions you posted show a length of 5-6 mm (same as my TV instructions).
My wall mount came with M8 x12mm screws.  The shortest screws I could find was 10 mm.  I’ll have to add a few washers
I’m really concerned that 5-6 mm into an 80lb tv isn’t enough!
