02-15-2025 02:49 PM in
TV & AudioHi folks,
does anyone know whether or not the Samsung 43-inch DU7700 LED 4K Smart TV and Galaxy A31 are compatible for Smartview in order to mirror/cast my phone screen to the tv screen?
Additionally will my phone screen scale to the fullscreen of the tv screen?
I recently bought a USB C to HDMI adapter only to find out my A31 isn't compatible and my current tv is an old one without wifi or Bluetooth so I'm thinking of buying a DU7700 but would hate to get it to only find out I still can't cast or mirror my phone screen onto the tv screen.
Thanks
Damian.
Solved! Go to Solution.
02-17-2025 12:25 PM in
TV & AudioHi Damian,
You can wirelessly mirror from any compatible smartphone, tablet or PC to the Samsung DU7700 - the feature is available on Windows 10, Android 6.0 and higher mobile devices (your Galaxy A31 is Android 10, upgradable to Android 12) that support Mirror Casting and the phone should scale to the screen of the TV.
Hope this helps :)
Hope this helps :)
